Hey guys, I installed eclipse to my phone and now it is saying that the Sim card is from an unknown source, how can i get rid of eclipse to be back to normal, and CWM isnt running for some reason...HELP
Droid Razr Utility 1.51 [Contains 6.12.173 Fastboot Files] - DroidRzr.com Then if that dont work download this utility on to a windows pc extract all, run bat file, get your razr into ap fastboot mode connect to pc via usb cable,make sure that motorola drivers are installed on pc first) then choose option to restore razr.
This will return you back to stock. Then you can root, rom,ect.
