Doit2it
Android Expert
I happened to go into my routers setup this morning and I saw two additional android devices listed other than my phone and tablet.
I was using WPA2 with a 26 character password of random numbers and letters. The letters were all caps, which would have been a slight degradation of the password's strength. I had WPS turned off, because I've read that's a vulnerability for cracking secured routers. Yes, I've had the password for a long time.
Now I have a random password more than double the length of the original. Numbers, letters (caps and non), and symbols. I also blocked the Mac addresses of the two android devices I saw.
I tried turning off my SSID broadcast, but neither of my android devices would connect even though I entered the password. My router help files state it should work, but it doesn't. Any ideas on that?
I know a longer SSID will make breaking more difficult to hackers. Mine is just 7 characters now (Doit2it). Vanity!
