Help i7500 dead after flashing
i7500 dead after flashing need help
:rolleyes:
phone rebooting... cant flash it :confused:
Download Start...
<0> Create File...
<1> StartThread Detected : 1
<2> StartThread Detected : 0
<3> StartThread Detected : 0
<4> StartThread Detected : 0
<5> StartThread Detected : 0
<6> StartThread Detected : 0
<7> StartThread Detected : 0
<8> StartThread Detected : 0
<1> setup connection...
<1> odin mode.. check plcatform verification.
<1> START!!!
<1> check download environment.
<1> arm9boot download..
<1> 1/8 Finished.
<1> amss download..
<1> 2/8 Finished.
<1> arm11boot download..
<1> 3/8 Finished.
<1> kernel download..
<1> 4/8 Finished.
<1> system download..
<1> 5/8 Finished.
<1> userdata download..
<1> 6/8 Finished.
<1> recovery download..
<1> 7/8 Finished.
<1> cache.img download..
<1> 8/8 Finished.
<1> reset pda..
<0> Started Timer
<1> Close serial port and wait until rebooting.
<1> PASS!!!
<0> Destroy instant..
<0> Killed timer
Have u tried flashing again ? In most times 2nd time should work just fine ... or another OS version ... maybe u got a corrupted one :confused::confused::confused: ...
i tried flashing again with another OS version
same problem
Download Start...
<0> Create File...
<1> START!!!
<1> 1/8 Finished.
<1> amss download..
<1> 2/8 Finished.
<1> 3/8 Finished.
<1> 4/8 Finished.
<1> 5/8 Finished.
<1> 6/8 Finished.
<1> 7/8 Finished.
<1> 8/8 Finished.
<1> reset pda..
<0> Started Timer
<1> PASS!!!
<0> Killed timer
and same problem doesn't swich on
Download Start...
<0> Create File...
<1> START!!!
<1> 1/8 Finished.
<1> amss download..
<1> 2/8 Finished.
<1> 3/8 Finished.
<1> 4/8 Finished.
<1> 5/8 Finished.
<1> 6/8 Finished.
<1> 7/8 Finished.
<1> 8/8 Finished.
<1> reset pda..
<0> Started Timer
<1> PASS!!!
<0> Killed timer
How long have you left it for? My 5700 took a few minuts before it loaded up.
Do you see the progress bar underneath the word Samsung?
what spica_ops file did you use?
Using an incorrect spica_ops file can cause a hung start at boot.
