Icon images turn to default - solution Desire HD
Ookami
Hi there guys I'm new to this forum and completely green when it comes to Android world.
I am a very happy user of Desire HD for over a month now and noticed that many times when unmounting SD cards or unpluging mobile from PC my icons image would turn to Android default image sometimes just for a little while but most of the time for good. Especially in folders. Now i don't know what exactly causes the icons to loose image but i might have found a solution to this irksome problem.
It's very simple really though I searched far and wide in internet and nobody could give a ready made answer.
All you need to do is go to your Personalize settings and open skins options and choose another skins even if for a while. For some reason this brings back all the original images even if the apps are in folders. Tested twice worked both times.
Hope it helps you too.
