Icons always go to first homescreen
silverfang77
If I'm in my app drawer, long press an icon and then press Add to Home Screen, it always puts the icon on the leftmost screen, even if I'm on another screen. This behavior started after I upgraded to Gingerbread 2.3.6. Is this a bug in the OS?
This is the way the new MotoBlur works.
To do it the way you used to do it with your Droid 2, you will need to install a third party launcher, such as Launcher Pro or Go Launcher.
