Help ICS Issues.. Bluetooth and Charging
MrAdos
Like most RAZR owners, I recently applied the ICS OTA update.
Two issues that I'm having, that were not issues when I was on GB (two days ago)..
1) No easy way to charge via microUSB cable to PC. The old "charge only" seems to be gone. I like to plug in my phone (to keep charged) and occasionally listen to music when I'm at work. The phone defaults to "mass storage" when I plug in the USB, so I can't access the music through the phone. The other connection options don't seem to help either, as they either stop the charging or mount the drives.
2) My Bluetooth headset (Plantronics Backbeat) is having issues with the play/pause functionality in my Media player of choice - MortPlayer Audio Book. After I initialize playing some file, I can hit the button which will stop the audio from reaching my ears, but the track keeps playing inside MortPlayer. It seems the only way to play/pause without any problems is by using the phone touchscreen itself . To make sure the issue wasn't with MortPlayer, I downloaded MixZing, and it has the same problem.
If someone can offer some workarounds, I'd really appreciate it. I was very pumped about getting the ICS update, but all the "cool stuff" doesn't really make up for the issues that I'm having.
(I really don't think this is related at all, but I should note that I have SU on my phone. I had rooted about a week before the update (motofail), and I was able to maintain root access by uninstalling and deleting 1 safestrap/bootstrap file, and using voodoo to temp un-root.... the issues above were not problems at all before or after rooting, but only came about after the update)
Thanks!
Have you done a factory reset? There are many problems caused by the ICS update that are cured by doing that.
I know its a pain, but it may help.
