Root ICS roms
I was trying to find a rom for my droid razr. Its 6.16.300.XT908. ACG.en.US. I have flashed some roms but they ask me to install my sims card and I dont use one. Thanks for the help
Unfortunately, most ROMs are "build specific", meaning they have to be flashed over a specific build number (such as the one you're running on now) if there isn't one listed that uses your build as a base, the ROM won't load.
