Idiot needs help setting up his wowway email
Pentegarn
Hi. I am sure this has been asked before, but I can't seem to find it anywhere using the search tool
I have tried searching for this and can't seem to get an answer. I am trying to set up my droid to get email from my wowway.com account. But I can't get it past the "checking incoming server settings" screen. It repeatedly gives the message, "Unable to open connection to server. I have tried the few things I could find on google but nothing is working. Any help resolving this would be appreciated.
Thanking you all in advance,
Tim
Tim
Do you have the proper settings, are you using IMAP, POP3? details!
I am using POP3 I believe. Brinkley's instructions worked for the incoming part of the setup. Now when it goes to the outgoing it gives me the same message.
I went and got the POP3 info from here:
AnswersThatWork's famous ISP List - WOW! Incoming Mail POP3 server and Outgoing Mail SMTP server, and DNS settings
And I entered it on the outgoing server settings as it was put there, however I still get the "Unable to open connection to server" message.
Do you know if it requires some sort of encryption key?
Tapatalk. Samsung Moment. Yep.
