Ignition Beta (LogMeIn for Android)
Noice!
...but, dammit, my pc at home is offline for some reason...damn Time Warner and their flaky service over the past couple of days.
Thanks for pointing this out -been waiting for this for a while.
Grabbed it, used it already to check on my PC & Mac works good enough!
Sadly it expires 05/31/2010 :(
Not sure i'd pay $29.99 for it IF that is what they price it at.
Getting odd behavior...tried to log in from my Droid, and it says the log in failed.
Tried again, said it failed again.
Looked on the PC, and it said I have two connections to the PC!
So someone is lying here... :) The Android client isn't reporting the connection successful, even though the PC client thinks it's connected...
Anyone else seeing this?
Third time it worked - I disabled and re-enabled the logmein client on my PC and tried again...
Also need some assistance...what does the third icon from the left do (the one that looks a little like a pie chart), between the Alt-Tab/Ctrl-Alt-Del option and the magnifying glass.
I don't like how you have to move the screen to the mouse and then click. Very odd way to do it.
