Okay so I got my G1 on 7/3/09. I love it so far, but I am a tad bit confused about this 1.5 upgrade cupcake thing. I was told mine would be up to date when it was activated, I don't think it is.. I don't because there is no virtual keyboard and it says I have firmware version 1.1 soooooo how long will it take to get the upgrade? and what exactly will it change?
Thank you soooo much!
-Brit.
You got it 7/3? Then give it a couple weeks to update on it's own. When they released cupcake they said that new phones would be updated like a week or two after the phone is activated.Okay so I got my G1 on 7/3/09. I love it so far, but I am a tad bit confused about this 1.5 upgrade cupcake thing. I was told mine would be up to date when it was activated, I don't think it is.. I don't because there is no virtual keyboard and it says I have firmware version 1.1 soooooo how long will it take to get the upgrade? and what exactly will it change?
-Brit.
that's a coincidence, mounting doesn't prompt the update.Brit-
plug your G1 to your desktop or laptop thru USB and mount it by pulling down the notification curtain when the USB logo is in the top left corner of ur G1 display.
then "Select to copy files to/from your computer." touch "Mount"
i got my G1 on 06/30 and had the update that night, it automatically prompted me to update after i mounted.
im using an iMac but i think itd be the same on windows, as long as your internet is connected.
