Help Im in a great need of help please someone help
jlede
Android Expert
My screen is completely destroyed and I need a everything like the display and touch screen I'm sure I can salvage the bezel does anyone here know where I could buy a new LCD+digitizer from a trusted site
THANKS FOR ANYONE THAT HELPS
wouldnt i need to remove the bezel but how ive heard leaving it in the heat helps but its like 17 degress here so i dont think that would help me suggestions
I'm not sure what you mean, sorry.
That's a link to a repair guide and replacement lcd and digitiser. Isn't that what you're looking for?
I wouldn't let any electrical device get too hot btw.
so I took off my screen just for a test and when I plugged in the battery (after i put it back together) it says its charging but i dont have it plugged up to anything
