Root im ready to give up!!
fgibson
Member
thanks to the wonderful threads on here i have found everything i need to unroot the spectrum, and i am so thankful for all of that however... the laptop and desktop both say that all the files are invalid once they download... i have to get this thing unrooted so i can send the phone off to the person who bought it bc they asked for it to be back to factory.. which sucks bc ill be out 250 bucks! but i dont want to sit on the phone as i wont be going back to it... any suggestions?
the errors i am getting are on the computer when i try to download the file, not sure if im not getting it all due to my crappy internet or what i have going on for sure, thats the thread i have been using Neph81 has been awesome in helping, i cant get even far enough to get the files to put them onto my phone, like i said im so frustrated its not even funny
Can you give a specific example of what errors you are getting? Is it when you try and open the .zip files in Windows or a different error.
windows can not open this folder.
the compressed zipped folder'c:/users/anthonys/downloads/v4_stock(1).zip is invalid
its (1) because i redownloaded it before i deleted the first one that gave the same error
u need to unzip file and,then move it sd card. it's in the directions if u follow them. download 7zip and use that.
okay, i clicked on it to unzip it and it says the compressed folder is empty, i am downloading 7zip as i am typing this, i tried to unzip it like i did with the allinone and it just isnt working. but i will be the first one to admit i am so not computer savy.
tried to open it in the 7-zip file manager and got the same error message as i typed in before.
How big is the file you are working with? The v4_stock.zip should be 724,191,279 in size. If not, then your download is most likely getting dropped mid way thru.
Are you using windows 7? If you are, can you try the following:
- Open your Downloads Folder using Windows Explorer
- Right-click on v4_stock.zip
- Select 'Properties'
- Go to 'Checksums' tab
- Copy the values after "MD5" and let us know what you see.
im on vista, i have a friend who has fast internet trying, she said it has 2 hours on it but ill try orbit. thank you
I think its best if you verify the MD5 hash to make sure you have a clean download: MD5: 8f092bfb0e817489e52307c43a3beead
Can someone else confirm the MD5?
You can use the Hash Check app at: HashCheck Shell Extension - FAQ
Download the files with your phone and use root explorer to unzip and place the folders where they need to be... that may be slightly easier for u...
Make sure you plug your phone up first!
Did that this weekend with the V6. Put a world of hurt on the battery.
Can I do that over wifi I have already switched phones
you can switch your sim back. Thats the beauty of a smartphone, as long as it's the same carrier your sim card will work in any phone you put it in.
but to answer your question yes you can use wifi.
downloaded the folders directly to my phone using the above mentioned app.. and went in and tried to follow all the steps that Neph81 listed, when i went into v4_stock to start it said that no files could be found. clearly i am not tech savy enough to do this. i dont understand what i am missing, i have tried everything that has been suggested on many different computers now, had a friend try to download everything and the v4_stocl file failed multiple times.
are you behind a firewall that is blocking downloads?
yes, if the md5 does not match, you would need to download the file again. maybe you can try the wifi somewhere else...cafe, library, panera etc?
what file size do you get when you download?
i get a 619mb file, i shouldnt be behind a firewall i have been on personal internet and it has never had any set up, thank you Neph81 i am working on that now, im sure my issue in our internet, we have wildblu internet and it sucks! but sadly where we live its out only optopn. again thank you guys for all your help
okay another issue (maybe the whole problem?) i redownloaded the drivers and then plugged it in and put it into debugging modeand when it goes to find the new hardware it asks for a disk and then when i click on i dont have the disk it goes into check for a solution and it says it cant find anything.. is there a way around this?
