Im stuck on desktop mode.....
BigCiX
Android Expert
How do I get out? Also, on the stock tool bar widget. What is that button next to the auto brightness sign. If its auto rotate then it doesn't work.
How do I get out?
Do you mean in the stock browser you're stuck in the desktop view? If so, go into the Menu, and down the list you'll find a checkbox for "View desktop site". Uncheck it.
That button (double revolving arrow) is to turn on Auto Sync. That's essentially a shortcut for Settings > Accounts & Sync > Auto-Sync ON/OFF. When it's on, it'll sync all accounts based on their respective sync settings. Keep it off if you want to limit your 3G usage.
try re-docking the phone and undocking, or re-dock, turn off while docked and turn on when undocked.
Might rejigg it so your back where you should be.
