Help In a need of Carbon ROM 4.4.4 for 320n
Hello,
like the title suggests, I am in a need of a carbon ROM 4.4.4 for 320n model.
I found the old post: https://androidforums.com/threads/unofficial-d320n-d325-ms323-kk-carbon-rom.938158/
but the download link leads to Gdrive with two folders, both containing a few kb files, with no actual zip file for the rom..
On the other hand, there is also: https://androidforums.com/threads/discontinued-4-4-4-ms323-carbon-rom-lg-l70.887313/
but it is labeled for MS323 devices. Maybe I can use this one?
I was wondering, does anyone have zip file for 320n device lying around?
Thank you for your time.
Hi, I'm the developer of the aforementioned ROM. I just checked the Gdrive folder where I'm hosting this particular ROM, it's still there for download :) Look better, zips are 196MB in size.
Those few KB files that you see alongside the actual zips are md5 checksums, as an added security measure for you to check if the zip you've downloaded is the actual zip I have built and uploaded.
Okay, wow.
In my defense, I don't use Gdrive at all :D, must've missed the file somehow.
Anyhow, thanks ( hvala :] ), and sorry for a silly thread. Cheers!
No problem, tell me how it goes with the ROM :)
Serbian:
Opusteno, samo mi reci kako se snalazis sa ROM-om :D
Okay, so I finally came home and decided to give it a go. Again, I came across the same problem, I was unable to locate the zip file. Perhaps I am doing something wrong?
Huh, you're right, but it's not me, Google flagged most of my files for "violating copyright policies" o_O Thank you for notifying me, because this affects my other ROMs too. I've made a request to remove the flags, so the files should be available in a few days, at least that's what Google told me. If it takes more time, or they don't approve of it, I'll reupload them somewhere else. Really sorry for this, just be patient now. If you're really in a hurry, I can try providing you these files in a message? And please remove the screenshot, my real name can be seen there :)
I'm so happy to hear that, it means I am not totally technology incompetent :D!
On the other side, yeah, I've noticed this behavior on other oldish ROMs too. There's no rush really, whenever and however you feel like sharing it :).
Sorry for that screenshot, it has been removed.
Thanks for fast response, cheers! :]
