Help In call menu - during a call, press 1
Hi,
1.) Model Number ? HTC Magic
2.) Firmware Version ? 1.5
I have searched the forums and the htc documentation, but cannot find any way to press a number key during a call. You know those numbers that you dial where you get a voice saying for option "A", press 1, for option "B", press 2, etc...
The only way I can seem to bring up the keyboard is by pressing the call button, but then it seems as though android wants to transfer the call to the number I am entering.
Does anyone know of a way to enter the number for the call you are on?
Thanks, any suggestions appreciated
Sorry, please ignore this, there is tab during a call that you can flick up to get the numeric keypad, this allows you to enter the required digits :D
It's really weird. You should be seeing a tab at the bottom which will bring up the keypad during a call. I'm using the Rogers HTC Magic with 1.5 Android and use it to enter my voicemail pin.
