Help In-call settings
RicardoW
When I take a call and look down at the screen, the screen has either gone blank or the call details have gone to the status bar. Where can I control how the in-call screen behaves?
The screen being illuminated is likely the biggest drain on a battery. There is a sensor on the front of your phone so it knows when you have the phone to your face which turns off the screen. It should light up once the phone is pulled away from your face. If it's not doing that for you, you may need to clean the area around the sensor. Sometimes a screen protector will also confuse the sensor. I hope this helps.
