Hi, folks.
I needed some cheap tablet for reading comics, so yesterday I bought budget Prestigio Grace 3157 3G (around $115).
It came with fully charged battery, it dropped to 96% and stayed there for three hours of constant usage, only to turn off without any warning. I put it on charger, it turned on to reveal 1%. Again, it was charging for more than an hour, stuck at 1%, and changed immediately to 63% when I unplugged it. Then it started to drop steadily (like devices normally do) to around 40%, where it again hanged for an hour, and then warned me that battery is at 15%, and then literally counted-down from 15 to 0 in a matter of a minute.
I saw on the customer support page that some guy also complained about the same problem on same tablet, and they told him to bring it back for checking. Also, on some Russian site I saw people complaining that the problem persisted even when Prestigio gave them new tablets in replacement, so it means it's not problem just with mine, but with whole series.
A friend told me I could calibrate battery and that's what I'm doing at the moment, but is it any good? Is this something that can be solved or should I go straight back, return it and demand money back?
Thanks in advance.
Thanks in advance.
