Incipio battery mod
kmf
Just bought the Incipio battery mod for my Z Force. So far so good. I like how the Command center widget shows both the phone and the battery mod charge levels. Anyone else using this mod?
Can't say for sure. I had it hooked up to the phone last night and used the Turbo charger and charged overnight. It can also charge on my Tylt Vu wireless charger.
Any updates on how this performs. I'm looking at external battery options and am really tired of the external through a cord mess in my pocket at work.
I have it, and agree with what you have said. I just don't need to use it very much. It was the very first mod that I purchased last fall.
It is fine. Gets through a long day with no need to charge externally.
I do not understand why the huge battery in Z Force is insufficient to get through the day, my old Turbo was good for the day; did it use less juice?? GSam battery monitor, my go-to battery app will not provide app by app usage in Nougat unless I root my phone. Any workarounds for this?
There is no case that will cover the phone with mod; only a dumb bumper that provides insufficient protection, I think.
If you find one, lmk. Or even another battery mod that will accommodate a real case.
I am using it. I like that it looks like part of the phone but I don't find that it adds that much battery life, considering the extra weight and bulk. Do you find it gets very hot, sometimes when it isn't even plugged in?
