Increased Battery Life
jradicle11
That Guy
Alright this is straight from the Droid X forum where nfriend21 posted this. I tried it out on my Droid 2 and noticed a huge improvement to battery life.
Allright guys, Im posting this because I have literally tried everything and I found the golden goose for maintaining a strong long battery life on your droid x. Here are the mission critical items:
1. battery profile options: in the off-peak hours section, make sure you "data timeout" is set to 15 minutes. in peak hours, make sure its at 15 minutes also. This wont even affect your phone use and I use text, email, sports, weather and other apps regularly with no difference.
2. battery should be in smart mode
3. Data delivery -> uncheck background data (sometimes this will re-check itself after using certain apps. If it does, dont worry about it. This might not drain your battery so much anyways.
4. wifi settings -> menu button -> advanced -> wifi sleep policy -> select NEVER (no, im not joking. do an internet search and read how this saves your battery).
Roll with this and you wont believe how good your battery life is. Yes, turning off wifi, bluetooth, and other things will help but if you do the above things you practically wont even have to worry about it.
And you definitely dont need task killers or cleaners. worthless.
If you dont do the above things, you will think you need task killers and other workarounds to save your battery when in reality they are the only problem.
Follow this and your battery life will absolutely kill any iphone battery on the planet by a longshot.
good luck.
Here's a link to the original thread.
http://androidforums.com/droid-x-ti...ery-life-if-you-know-how-use.html#post1415857
I don't think there's a "Smart" mode on the D2, I use the custom option opting for 15 minute data sleep regardless of the time. Here's what I found helps a lot too:
1) Drain the battery all the way until it shuts down and then recharge completely while the phone is turned off. (Do so a couple times.)
2) Battery set to Maximum Battery Service
3) Background Data Enable is "un-checked" it'll re-check itself for some apps, which then you can eaither leave on or turn back off.
4) Screen brightness I have at 25% indoors, and automatic outdoors.
Can you have a setting where your phone knows to go to auto brightness when your outside? I see you guys keep mentioning something about it.
Most people just keep it on auto the entire time, I use the "Power Control" widget from the Android Widgets menu. Anytime I step outdoors I simply tap on it to switch from the low setting to Auto, and then back when I go indoors. For some it might be "too much work" but I think its worth the hassle.
I've noticed a definite improvment in my battery. One Problem, as a result of Unchecking the Background Date in Data Delivery, I no longer get email notifications. Emails don't even appear unless I go into my gmail and refresh it myself.
Any ideas on how I can fix this problem? I like the better battery life, but I like getting notifications for my emails as well..
After using these settings and reducing my brightness to next to nothing (which is still plenty bright) as well as getting rid of my task killer I've increased my battery life from about 4 1/2 hours up to 10 hours and 20 minutes now (with 5% remaining). That average of 4 1/2 hours comes from at work when I just surf the web and market and watch a few YouTube videos. Today I've been running Pandora nonstop (on Wi-Fi) for the past 9 1/2 hours. I am more than pleased with this significant increase in battery! This might be the battery getting broken in as well since I only got it on Friday. If anyone else has any questions or can offer any other tips let me know!
PS: With the 4 1/2 hours my display usage was around 55% and that was with my turning the screen off for periods of time. Today I've had it set in Pandora so the screen doesn't turn off and it's at 57%! I still can't get over how well it did today!
Im currently at 14h 16m since unplugged. I had horrible battery life but I did some battery conditioning and have gotten these results. I hope to get even better results with these settings in effect also.
I want to test it out with normal use for as long possible but I just can't risk my phone going out during school. What ever would I do to pass the time...
I usually just refresh GMAIL manually once an hour, at work GMAIL and most GOOGLE services are blocked by our corporate firewell so the fact alone that now I have a way to get to my GMAIL is an incentive enough to just save battery and check my email when I do actually have the time to since I don't want to be the "young kid" in the office always on his phone.
After conditioning my battery for a few days, and setting my screen to time out after 30 seconds instead of a minute (My display was always 60-75% of the usage) I went from needing to charge after 6 hrs, to being at 30% after 13h 14m unplugged.
I left the brightness on auto, Battery is on nighttime saver, and didn't turn BG data off (I use the email too much for that)
I watched around 25 minutes of video (youtube and G4), had pandora running for around 4hrs (Both on wi-fi), sent and received about 200 texts, did several emails,navigated home from work (about 25min drive, and I just wanted to try it...)and spent 45 minutes on the phone.
My display is 34%, voice calls 12%, phone idle is 11%, wi-fi, maps, standby, and media server are all 10%, with A.S., com.moto.home, broswer and texting all <5% each.
I'm going to try the wifi sleep thing, just to see if that helps at all.
But all in all I'm really happy with the way it is turning out, I was ready to take it back the 2nd day I had it...
Yeah, I gave up on turning off the Background Data. It's on now. My only qualm is the my favorite game is a MAJOR battery hog, moreso than the screen itself.
I've done all the settings except for the background data one...can't manually refresh as I get time sensitive emails sent to me daily. Outside of that, I'm hoping this works. I've been getting about 8 hours on LIGHT use with almost no video, music, or web browsing. Concerned me but then again I probably wasn't conditioning the battery right since yesterday was the 1st time I let battery run down to 5% before plugging in.
Without disabling background data, I don't believe you'll be getting as good of battery life as me or some of the others. I should be significantly better, though.
I get about 24 hours with data left on. I have K9 mail set to update every 5 min and it dosent drain my battery too much. I havent been texting alot, but I get emails and check them constantly and I do watch some video.
Ok so I tried some of these and I didn't like that my gmail didn't push anymore so I turned the background data back on but my gmail still isn't pushing and I have to go on there and refresh it to get it to bring in emails. Anyone know how to fix this?
Running the battery all the way down on these types of batteries won't help, doesn't improve battery life...battery life will generally improve after a few cycles, but you don't need to run it down to out or almost out.
You can drain it all the way every few months to sync the battery level meter, but don't need to do it to "condition" the battery.
You'll get the longest life out of your battery overall if you don't run it down much past 30% or so on a regular basis.
That's not what it says here under "Train Your Battery".
