Increasing Stylo's volume.
Marty_Since87
Android Expert
[DISCLAIMER] I use this for my T-mobile LG G Stylo this also works for the MetroPCS variant, I don't know if it'll work for any other variant. therefore I'm not responsible for what happens if you decide to use this, as always please make a backup before proceeding. You also must be rooted in order for this to work.​
This is what I use to increase my volume I forgot who was the originator of this file but
HUGE SHOUTOUT TO HIM!!
These are the steps I was told to take :
1. download ---->THIS<----
2. open your file explorer [I use root file explorer] and look for the file you just downloaded "tweak2.AUX.mixer_paths.xml" then copy and paste it into SYSTEM-->ETC
EVERYTHING WILL BE DONE IN THE ETC FOLDER
3. Find the "mixer_paths.xml" file copy the name then rename it "mixer_paths.xml.old"
4. Find the "tweak2.AUX.mixer_paths.xml" file and rename it "mixer_paths.xml" or just paste the text you just copied.
5. After you renamed the file, find it and Change permissions as seen in this screenshot, after that hit "ok"
6. Reboot into recovery and wipe cache and delvik cache.
7. Hope I helped.
You can also combine this with:
Dolby Atmos
download zip and flash it via TWRP​
I done this a good long while ago and then install Dolby Atmos,
Shouldn't this be in Root section since ya need root access to write to system/etc
I'm sure an Admin will see it and move.
Yup I take root for granted now for as long and many devices I've rooted and use it on them... I'd feel broken and disabled if I were to use a phone that couldn't be rooted. hahaha
