Insane phone radio power consumption
How is your signal strength? It could be searching for a phone signal is it is weak.
I don't think the "phone radio" results are for the data portion (4g or wifi), it's for the phone signal (cell signal). (I could very well be wrong about that :p )
But, 7% in just over 5 hrs and 1.2%/hr in my opinion are not too bad.
I usually average 4-5 % /hour and right now am at "Used 50% in 12h 23m"
How long does your battery last between charges?
Oh I forgot i put it on a charger 10 minutes in meantime, well it lasts for 4H of screen on time and about 10-15 hours a day usualy before I need to charge it.Phone has insanely good sleep time, it uses almost no battery, but when I use it leaks, even if I only use whatsapp messaging it drops insane
It is like this, ok it is lot of data today, but percentage like this is usual, is there any other software that can check what is using battery? Phone is rooted, so I am flexible regarding apps
