Apps installation problem
rahish
hi pal,
i just downloaded the latest version of the android sdk,and the eclipse version ganymede 3.4.the plugins for avd in the eclipse installed,but i cant access the avd..
when i started the sdk installation,all the packages downloaded,but i dont have any existing codes,and the fetching the URL always fails...even i forced in the settings,it fails,after that a blank window with no packages is shown..how to get those packages..
the installation and usage steps are needed to be explained clearly,i am using vista 32BIT,
reply pal,clearly as u can
