Intent Questions
Hello. I followed a YouTube video about creating a WebView and from that I created an Intent button with a Share Function, everything worked normally but after that I was trying to create a Call button with Intent which is working also, but now the share buttons have two functions, call and share.
How can I remove the call function from Share?
case R.id.myMenuFour:
Intent shareIntent = new Intent(Intent.ACTION_SEND);
shareIntent.setType("text/plain");
shareIntent.putExtra(Intent.EXTRA_TEXT, myCurrentUrl);
shareIntent.putExtra(Intent.EXTRA_SUBJECT, "Copied URL");
startActivity(Intent.createChooser(shareIntent, "Share URL"));
case R.id.myMenuFive:
Intent callintent = new Intent(Intent.ACTION_DIAL);
callintent.setData(Uri.parse("tel:phonenumberhere"));
startActivity(callintent);
Thank you,
Raul.
FIXED! I forgot to add break;
Noob here :( sorry.
First thing that is obviously wrong with your code is that the case statements are missing a break statement.
Normally in Java, a switch block has the following syntax:
Code:
switch(expression) {
  case x:
    // code block
    break;
  case y:
    // code block
    break;
  default:
    // code block
The 'breaks' are necessary, because otherwise the execution falls right through to the next case block, even if it matched the previous one.
Code:
  case x:
    // code block
    break;
  case y:
    // code block
    break;
  default:
    // code block
Hello LV426, I figured it out after I posted here, thanks for the heads up!
