Help Internal Storage Problem
Laslo
Hi guys , pleas help me I have LG L70 with 4.4.4 MIU Rom and my internal storage is full , no apps instaled no music , only the system is instaled , I tried to wipe data ,cache but nothing.. helpp
That's the only really bad thing about the l70 is extremely low internal storage. I just partitioned an SD card and used link2sd to all the apps I install to SD, just have experiment on what apps to not move their internal data cuz some misbehave.. There's tuts all over here for it
You could wipe internal storage and flash the rom again. Also why do you use a custom kitkat rom instead of stock? I thougt that the goal of flashing a custom rom was upgrading android. I recommend you Nameles rom, i've benn using it a while and is great.
I use KK a lot and would use jb if there was one for this model. Sometimes up grades are not always improvements and you can do things with older roms you can't with newer and vise versa. Plus personally older Android looks so much better than the whole material design disaster lol but that's just personal preference
