Root [International] Help with creating VPN connection
Bobbi2012
I've had my SIII for 3 months now and I like it. However, I've been trying to create my VPN connection and haven't been successful yet. (don't know why) But does anyone know how to edit (or even view the parameters) of a VPN connection that I've created? After I create it, I try to connect and it says unsuccessful (after awhile). So then I'd either want to edit the setup or even just to Delete the named connection so I will start again with a new setup. I managed to setup a friends Android tablet so I know it can be done. HELP????
You saved me. I couldn't find any notes about that in the User Manual.
So I was just able to delete a couple of bad tries and go in to Edit the error on another and voila! I have VPN running.
Really, thanks so much. a lifesaver today
I had the same issue
first time I noticed that I had my preshared key entered incorrectly
next time, I noticed that my password was wrong
so make sure all the fields are correct again and it should work
