Hello guys and gals
Galaxy S3 I9300
Android 4.1.2
Rooted Stock ROM
Siyah Kernal
I downloaded v1.3.7 from Play the other day and applied the patch as requested but I have yet to get this lovely app to work for me.
After opening the app, I am presented with the enable/disable apps screen and I select the ones that I wish to use, hit save and reboot. After reboot, I enable Multi Window and pull out the tab. The tab is always empty so I tap edit, after which I am presented with a screen of app icons that I am able to drag to the flashbar, I then tap "Done" and all is good.............except when I reboot again (for whatever reason). Even though after reboot and Multi Window is already activated, there is no flashbar tab - So I deactivate/reactivate Multi Window and the tab reappears empty again. I have cleared the data from the FlashBar but alas this did not change anything....
Am I doing something wrong here?
Any assistance would be greatly appreciated.
Many thanks and best regards..
Galaxy S3 I9300
Android 4.1.2
Rooted Stock ROM
Siyah Kernal
