hi guys just rooted my s3 now got omega rom put it on sd card pressed all the buttons what i get is
apply updates from sd
wipe data
wipe cache partition
apply update from cache
i do the apply update but just get error
any idea whats gone wrong thanks for any help
If you rooted with that guide sorry for jumping to conclusions. Did you wipe data, cache and dalvik before trying to flash. I'd also recommend going to mount in recovery options and format system. Although before doing all that download titanium backup and backup all your apps and also make a nandroid backup in recovery mode via the backup and restore option.
wipe data
