Root [International] s3 stuck in "Samsung galaxy SIII GT-I9300"
pgbone
hello all !
could plz anyone help me?
my s3 is just stucked with the title "Samsung galaxy SIII GT-I9300"
i can go to recovery mode, but when i try to "wipe data/factory reset" says:
error mounting /sdcard/.android_secure!
skipping format...
data wipe complete
and in "show log"
formatting /sdcard/.android_secure...
I: formatting unknown device.
mount: mounting /dev/block/mmcblklpl on /sdcard failed: no such file or direcory
w: failed to mount /dev/block/mmcblklpl (file exists)
skipping format...
data swipe complete"
i go to "download mode" and try all the versios of CF-ROOT 6.0 6.1 6.2 6.3 and 6.4 with odin 3.04 but still stuck !!
one thing i remembered is to format the sdcard because i didint want the current firmware...
when i root my s3, i used odin 1.85 and cf-root 6.1 but even if i try the same process again it didnt work =(
help plz, i just want use my s3 =/.....
thanks!
oh nice! i'll try!
but how can i know where country my s3 came from?
you say "flashing that", is put this firmware in PDA and execute?
thanks
Yeah put the firmware .tar in pda and start.
For the sake of getting your phone up and running any of the i9300 firmwares will work. The firmware from one country will work on a phone from a different one as long as it is i9300 firmware. So if you want your phone to be carrier branded choose one for your network, if you want unbranded go for the latest unbranded
