Root [International Tegra 3] Help.... Stuck in boot following restore from CWM
Hi all, thought I'd give you all a laugh...
I've run rooted devices before, but had kept my One X stock, until I decided I fancied a change over the weekend. Famous last words.
I'm no expert, but can generally follow instuctions.... I followed a video on onexroot.com (and used provided tools), and unlocked bootloader, rooted, backed up, and installed a custom rom (PacBAM), as well as flashing boot image just to make sure it all worked.
Initially I had a problem as I'd not realised I needed to flash boot.img, but I restored and started again, and all worked well.
My problem is this - I then decided after a few hours I didn't like PacBAM, so decided to restore my back up from recovery and start again. Basically, I've restored and everything seemed to behave properly, but now it's stuck in boot and nothing I do seems to work.
As I say, I'm no expert, but could anyone point me in the right direction please. I've tried and read various things and thought it might be something to do with the boot.img, but I'm not sure how to resolve it? :crying:
The tools I used to root are here. How to Root HTC One X! | OneXRoot.com
Graham.
Have you tried clearing both caches in CWM?
Because you can't write to the boot partition in recovery, even when restoring, you need to flash the image manually.
Does the phone mount to your PC in recovery?
