Root [International Tegra 3] Stuck trying to root - please help
NutterzUK
Hi,
I was following a guide trying to root my One X. I think I nearly got there, but now i'm a bit stuck.
I put clockworkmod on it. When I boot holding down the power key, and then go into "recovery", it goes to the clockworkmod menu.
I then downloaded cm-10.2-20130920-NIGHTLY-endeavoru.zip from CyanogenMod Downloads. I mounted the device and put the zip on the sd card. I then selected to install from zip, selected it and it said it installed ok.
When I reboot the device, I just get a white "HTC Quietly Brilliant" screen, and nothing else.
Any ideas what is wrong here? I can get back in to that clockworkmod screen by holding down the volume down and powering it up.
Thanks,
Hi, thanks for the reply!
I didn't, no. Do I need to find one specific to the ROM I put on or any old one?
If you can give me some direction on exactly how to do that / where to get the files I would really appreciate it. The guide seems to have missed it out.
Thanks,
Absolutely perfect, thank you! I now have it all up and running.
Thanks again, I hope you have a great weekend. I really appreciate it.
