Root [International] XPosed Help
ViralGold
Hey all,
Reflashed NeatRom etc etc etc blah blah :D
Basically all my options in Xblast and Wanam are back to default somehow and for the life of me i can't figure this problem out, i want to get rid of the background behind the Wi-Fi and mobile signal so it's transparent and only shows the bars of the signal as it fluctuates up and down ;)
I had it set up that way before i flashed but can't figure out the settings to get them back like that, lol. Tried for hours but my pea sized brain isn't in working order today :p
P.S. On a side note, how the hell do you change the font on your phone? The defaults on the ROM i'm using don't seem to be compatible for some reson and when i try the play store none of them seem to work either, anyone tell me where i'm going wrong please. Maybe this is something i need to ask Sale about but i'd rather try some off the play store 1st.
Cheers.
EDIT - Whilst looking for a way to change fonts i came across this post, seems there's a lot of useful info on there.....
http://www.androidauthority.com/how-to-change-the-fonts-on-your-android-phone-32078/
Which led me to this app, i installed it and it worked, the article says it can be used for rooted or non rooted devices.
https://play.google.com/store/apps/details?id=com.kapp.ifont
Not sure if you ever managed to get this sorted - but I'm guessing what you're after is a module you can download through the Xposed Installer. The one you'll want is EverythingTweaks. It gives you a transparent status bar/notification panel plus others... You can search translucent, but most modules are for SE/nexus phones...
