I used to run it with 600mb at 80 percentage swappiness and it made my phone multitask like a monster!
Far less refreshes when I moved between apps but there was a bit of lag sometimes.
With zzmove governor and zram it was a pretty smooth and multitasking experience.
Personally I think it's well worth it as the multitasking is garbage on this phone :thumbup:
I had mine on the same setting. Maybe it was the governor that made a difference. Or maybe it was because I was using ART.
It's a very good governor tbh, turns them all off when unused and ramps up quickly under load.
By refreshes do you mean when you swap to an app and it opens but is blank? It would certainly be nice to eliminate this.
Yeah exactly that, it does my nut in. It's minor frustration but something that shouldn't be happening on a phone of this quality
I might give that governor a try. Do you not use zram anymore then? (I noticed this is all in the past tense)
No not at the minute, because I'm flashing nightlies almost daily I can't be bothered setting up a new kernel each time (I use Yanks kernel religiously which is a one set up process when you first flash it)
It's pretty good with ART but I still get those blank apps sometimes that need refreshing. (Actually Chrome always needs refreshing, but I think that's the app...)
I might give it another try, but how is your phone set up now yatezy?
Just using omni with its own kernel and no over clocking and playing around, I'll wait until it's feature filled and stable before I do that :thumb:
