Hi,
I have recently updated Apollo to version 2.2.
I have a strange problem when trying to use applications that needs network access, programs like:
GMail, Maps, Youtube, Marketplace
They all work ONLY when using WIFI to connect internet. When outside WIFI programs says there's no network available.
On the other hand, the program Internet which is used for www-browsing works both WIFI / mobile connection.
In settings I have selected correct operator and enabled "use packet data" option.
Also in status bar there's 3G icon and under that arrows up/down indicating data traffic.
When trying to use for example GMail to check mails, the up arrow blinks every now and then but it can't get mails retrieved.
Any ideas what is causing this strange behaviour and how to fix it?
