Is it okay to run a 32-bit system service on an aarch64 android?
Erez St
Hi experts,
I'm trying to deploy a system service on Android running on 64-bit ARM (aarch64).
The service cannot be built for aarch64 (due to portability issues), and only runs when build for 32-bit ARM. I am able to install and run it when built for 32-bits, but I'm concerned if it might cause any other problems.
PackageManager outputs warnings about incompatible ABIs, and also I found a reference that says "All apps that use a given sharedUid are expected to use the same instruction set". In my case, sharedUid is android.uid.system
Can someone help clarify what are the implications of installing a 32-bit program in a 64-bit Android system, especially as a system service?
Thanks,
Erez
