Help Is it possible to fix the system without losing any apps?
I have a Samsung Galaxy A8, which was heavily rooted and modded, to the point that there are errors almost everywhere on it now. I can reset my device, yes, but what i'm sad about are the apps on my phone. I've installed about 200 of them and really don't want to install of them again due to the reset ( i do use all of them ). So my question is : Is there any possible way to reset device's system back to it's origin but all the apps are kept?
By the way, are there any sort of apps that manage a lot of apps like Greenify?
I don't think so. A system reset does completely reset and clear the phone. All your apps and games can be installed again automatically from your Google Play account.
I know Samsung Smart Switch can backup and restore apps.
You could try to clear the cache and see if that helps
A factory reset however does nothing to any modifications made to the system, so will not restore the device to stock. You need to reflash the firmware for that.
Then does flashing the same firmware to the firmware that's installed on phone without uninstalling it ( overwrite ) would work?
I was actually meaning app to manage apps whenever they should use, because many time i don't use apps, but i still see them running in background, consuming a lot of RAM and CPU unnecessarily.
Dalvik-cache & cache wipe didn't work.
Seriously, do not worry about backgrounded or paused apps consuming RAM. This isn't Windows 95 we are dealing with here, Android is perfectly capable of managing RAM, and in order to maximise the efficiency of the system Android will aim for high RAM usage: it will keep recently and frequently used apps in RAM to save both time and power when you next switch to them. Anyone telling you it is good to have a lot of free RAM in Android does not know what they are talking about, and any app that claims to help you achieve this state should be removed.
Now if you see apps consuming significant cpu cycles in the background that's different, because that's abnormal behaviour. Though if they need to listen for messages or similar then they will need some service running to do that, so consider what the app is doing before you decide it is wrong.
However, this is different from your original post, which said that you had constant errors, which I took to be because you'd modded it to the point where it was unstable and wanted to return to stock. If your problem is in fact that you have misbehaving apps I don't see how returning to stock will solve it (unless the apps that are misbehaving rely on root access, in which case they'll stop working - but you could rescind their root access if you wanted to anyway). A stock phone has fewer ways to control apps than a rooted one, and if an app is misbehaving I would always look at the app rather than the OS.
Anyway, if you want to return to stock (as your first post said) you'll need to flash stock firmware. You'll need to ask a Samsung expert whether this will erase your apps and data or not, but I'd anyway not do it without making backups first (and remember that recovery backups or Titanium backups won't work when the phone is returned to stock). Most manufacturers' system flashing tools reset the phone as well (so wipe everything), though with some there are ways of doing it without a reset. I've never done it with a Samsung, so can't tell you about them.
If you are using a custom ROM you can flash the same ROM over it without wiping first. That will only make a difference if you have messed-up something in the ROM though. If you try to flash a different custom ROM, or a stock ROM when you were previously custom, then doing a wipe (i.e. a reset) first is strongly recommended. If the ROM is sufficiently similar to the current one it might work without, but if it's very different (different base OS, AOSP vs TouchWiz, or just a sufficiently different set of mods made to the base) it probably won't boot without a reset, or may suffer more subtle errors in use.
Thanks for the info. It's just i've been receiving processes runs all of a sudden recently ( for example : Facebook suddenly takes 80% while i'm using other apps, or a lot of wild processes wake up at the same time and use about 10-20% of CPU, overheating the phone ). I thought that was the result of my phone having tons of app ( 250 user + 267 system, xposed ), so i thought stuffs like Greenify could work.
The damage i think i had done was flashing some kernels for the phone i found on xda, but later because the phone went super hot and sometimes i can't unlock the screen, so i decided to flash overwrite the firmware ( flash original firmware while it was already installed on the device without removing it ). It was taken out of my device, as of the result, but since that day i feel like the phone was never smooth like before, so i ask on here to see if that actually works.
