Help is it true that you can't pull out the battery?
How come? what would have happen if the phone freeze? you know, it would be possible that your phone freeze, then what can you do? you can turn it off, you can't restart it, you can't hard reset it, then what would you do?
You are quite right, you can't remove the battery but you can do a system reset just press your On/Off button and the Home (middle) hardware button together and the phone should reboot itself.
Thanks. can you clear this thing for me too?
- The internal memory is about 128MB (RAM). but I heard that we can install the apps/games on the memory card (like 8/16GB memory) and run them without any problem about the memory, is that right? I mean is there any problem about having a limited space for install apps/games or not?
thanks
No you can't install apps on your SD card. This comes with Android 2.2 and as recently announced none of the current Xperia phones will get anything more than 2.1.
There is an app called Apps2SD but I think you have to be rooted to use it. In fairness I have the X8 which has the same size memory and have loads of apps installed with no problem, in the region of 30. I don't use the phone for major gaming just AngryBirds and Wordfeud so the bigger games may be a problem on the phone but I don't know enough to comment.
Thanks, I was talking about the apps2sd thing. so can I root the x10 mini and then install apps/games on memory card? or is there any problem about rooting x10 mini?
I am afraid I am not the best person to ask about rooting as its not something that I have felt the need to do on either of my phones. There are plenty of threads here and over at XDA developers on rooting the phones, how to's etc so have a look around and see what you think.
