Johnny Cakes
PROBLEM SOLVED: Check out this thread.
I have Sprint S3 model.
I am attempting to do some mods to have the Verizon Qi charging rear cover door work with Sprint. Only problem is that the Qi charging coil and magnet on the Verizon Qi charging door covers the battery. Since Sprint has the NFC antenna in the battery, the NFC ceases to work.
The Verizon door seems to have the NFC antenna built into the rear cover itself, and then two contacts to connect it to the phone. Can anyone with Verizon confirm that that is correct?
In this photo, I have circled the Qi circuit in green and what I believe is the NFC circuit in Red. Can anyone with Verizon confirm that the Verizon branded phone has contacts that would match up with the contacts circled in red?
Thanks!
Thanks!
