Is note 3 compatible with wireless charging
Bigjake93
Hey guys I just bought a galaxy note 3 around a month ago and was wondering if I could use a wireless charger for it I have a bad habit of knocking my phone of the table and have had phones in the past break when the charge comes out and figured I would see if this would work
Almost any phone is "compatible with" wireless charging. You'll need a Qi charging pad and a Qi charging receiver made for the Note 3. Fit the receiver inside the phone, over the battery (there are contacts next to the battery that the contacts on the receiver have to touch) and place the phone on any Qi charging pad. If you don't want a thicker phone, look for a receiver that fits the standard back. (It makes the back a little harder to snap into place - they can't make a receiver with NO thickness.)
