Is there a one-click better app then MyBackUp Pro?
TeamPEZ
So I did a hard reset this am in hopes of eliminating the sluggishness of my Hero. However, I found out that I had to install each and every app that I had, instead of a "Click here to reinstall everything." I only saved the apps that I wanted/needed, so I feel as if I got cheated by buying this app.
Any ideas?
Thanks!
I noticed when playing around with Astro file manager the other day that it allows you to back up apps onto the SD card - maybe it also allows restore?
I'm pretty sure that there is no way to mass install apps. If there is I'd love to know as well.
Perhaps he is thinking of the Palm days when backup apps (i.e. "Backup buddy", and "Backup Pro") actually restored your entire device to the way it was, PIMs and Apps included as backup apps are supposed to.
I too was unaware that MyBackUp Pro does not restore your apps after paying $5, feeling kinda slighted myself.
You can restore the apps, but you have to do one at a time. You can't do a "one-click" install.
I wish we could though.
I never had a Palm, but I also wish I could do a "one-click" restore. It would make wiping a lot easier.
