Help Is There A Way to Access MTK Engineering Mode on a Non MTK Android Phone?
Slyseanx
Hi. I currently have a LG Tribute HD LS676. After a couple of Android and Software Updates, for some reason, the volume and the speakers were effected immensely.
Actually, the Volume/Speakers on this Model of phone weren't that great to begin with. So, I have tried countless Apps promising to boost volume with some success (i.e. Speaker Booster, Volume Up, Volume Booster, etc.), but the results have been temporary at best.
I have stumbled across MTK Engineering Mode (Apps) as a possible solution by a couple of users experiencing similar issues with the Volumes/Speakers on their phones. The problem is, the LG Tribute HD LS676 is a non MTK Android Phone. So one cannot access Engineering Mode.
Without Rooting my Phone, I was wondering if there's away to increase the Volume/Speakers? Is there a way to access MTK Engineering Mode on a Non MTK Android Phone? There must be something I'm overlooking.
Help is very much needed. Thanks :)
As this phone has a Qualcomm Snapdragon processor, it will NOT have Mediatek MTK engineering modes in it, that's it. It may have Snapdragon engineering modes in it though?
Have you tried just resetting it, which is something you may have to do after updates like that.
After any or all Software/Firmware Updates, my phone automatically reboots. I have tried almost everything aside from a Factory Reset--which would be my last resort.
