I have a SG3 from ATT running JB. The reject message is on the very bottom of the screen. When I pull my phone out of the case while it's ringing I many times end up pressing that area and rejecting the call by accident. Is there a way to disable it or an app I can install?
I think you may get a little more help in the S3 section of the forum so I moved you there. This is something that is included in Samsungs touchwiz interface so not every phone has it.
I don't think there is a way to disable this. You could install a different lock screen from the Play store like Widget Locker. There are others in the play store. Doing this would change how your lockscreen looks and functions.
Well you'd have to hide the entire incoming call within widgetlocker. Settings > popups > Hide incoming call. Thyat way you have to unlock the phone before you can see who is ringing.
