johnnybopper
Quick question, cannot find an answer to this anywhere!
I have a bash script to download a torrent link, and run it automatically with Transmission, which works just fine on Transmission, but I cannot get it to work on Android because of the Settings menu on uTorrent and other similar apps.
The script is simple:
$ wget <url> --output-document=index.html ; sleep 5 ; grep -i tvshowname index.html | grep "Torrent magnet link" | awk -F "href="" '{print $2}' | awk '{print $1}' | sed -e 's/"$//' | while read line ; do /usr/bin/transmission-gtk "$line" ; done
My Android is rooted, but I cannot get past the "Add torrent" section where you select files to add. Because of this, the uTorrent will open but will stop at this screen. It just needs to have "Add" clicked, or the option disabled. With Transmission, there is an option to deselect "Display a window when opening a magnet link", but there is no such option with uTorrent, and obviously Transmission is not available on Android.
Does anyone have any suggestions on how to get around this? Thanks
