Jacob Paisley
I'm trying to create either a WifiConfiguration object or PasspointConfiguration object in my Android application that will allow me to connect a device to a Passpoint network upon being enabled.
I've tried to connect by building a WifiConfiguration object and adding it to the WifiManager, then enabling it.
I have also tried to build a PasspointConfiguration object, but when I try to run WifiManager.addOrUpdatePasspointConfiguration() with the PasspointConfiguration object, the app crashes with an IllegalArgumentException. I'm assuming that this is an invalid configuration issue.
I expect the application to connect the device to the Passpoint/Hotspot2.0 network upon one of the configurations being added to the WifiManager.
The first approach does not produce an error, but does not connect the application to the network.
The following is the stack trace from the PasspointConfiguration IllegalArgumentException:
// WifiConfiguration/WifiEnterpriseConfiguration approach
WifiConfiguration wc = new WifiConfiguration();
wc.status = WifiConfiguration.Status.ENABLED;
wc.isHomeProviderNetwork = true;
wc.FQDN = this.domain;
wifiEnterpriseConfig.setIdentity(user);
wifiEnterpriseConfig.setPassword(key);
wifiEnterpriseConfig.setAnonymousIdentity(this.outerID);
wifiEnterpriseConfig.setRealm(this.realm);
wifiEnterpriseConfig.setDomainSuffixMatch(this.domain);
wifiEnterpriseConfig.setEapMethod(this.eapMethod);
wifiEnterpriseConfig.setPhase2Method(this.phase2Auth);
wifiEnterpriseConfig.setCaCertificate(this.cert);
wc.allowedKeyManagement.set(WifiConfiguration.KeyMgmt.WPA_EAP);
wc.allowedKeyManagement.set(WifiConfiguration.KeyMgmt.IEEE8021X);
wc.enterpriseConfig = wifiEnterpriseConfig;
wifiManager.disconnect();
this.networkID = wifiManager.addNetwork(wc);
wifiManager.enableNetwork(this.networkID, true);
// PasspointConfiguration approach
Credential.UserCredential userCredential = new Credential.UserCredential();
userCredential.setEapType(21);
userCredential.setPassword(key);
userCredential.setUsername(user);
userCredential.setNonEapInnerMethod("MS-CHAP-V2");
Credential credential = new Credential();
credential.setRealm(this.realm);
credential.setUserCredential(userCredential);
credential.setCertCredential(null);
credential.setCaCertificate(null);
credential.setClientPrivateKey(null);
credential.setClientCertificateChain(null);
HomeSp homeSp = new HomeSp();
homeSp.setFqdn(this.domain);
homeSp.setFriendlyName(this.friendlyName);
PasspointConfiguration passpointConfiguration = new PasspointConfiguration();
passpointConfiguration.setCredential(credential);
passpointConfiguration.setHomeSp(homeSp);
wifiManager.addOrUpdatePasspointConfiguration(passpointConfiguration);
Process: com.***.***.***, PID: 4101
java.lang.IllegalArgumentException
at android.net.wifi.WifiManager.addOrUpdatePasspointConfiguration(WifiManager.java:1483)
at com.***.***.***.models.<PrivateClass>.<PrivateMethod1>(<PrivateClass>.java:197)
at com.***.***.***.models.<PrivateClass>.<PrivateMethod2>(<PrivateClass>.java:219)
at com.***.***.***.models.<PrivateClass>.<PrivateMethod3>(<PrivateClass>.java:116)
at com.***.***.***.UserView.<PrivateMethod4>(UserView.java:178)
at com.***.***.***.UserView.access$100(UserView.java:34)
at com.***.***.***.UserView$2.onClick(UserView.java:200)
at android.view.View.performClick(View.java:7327)
at android.widget.TextView.performClick(TextView.java:14160)
at android.view.View.performClickInternal(View.java:7299)
at android.view.View.access$3200(View.java:846)
at android.view.View$PerformClick.run(View.java:27774)
at android.os.Handler.handleCallback(Handler.java:873)
at android.os.Handler.dispatchMessage(Handler.java:99)
at android.os.Looper.loop(Looper.java:214)
at android.app.ActivityThread.main(ActivityThread.java:6981)
at java.lang.reflect.Method.invoke(Native Method)
at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:493)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:1445)
