Help Is There A Way To Remove The Internal Battery For The Alcatel A30 Fierce?
MeganH1998
So I'm wanting to remove the battery inside my Alcatel device (Alcatel A30 Fierce), but for some reason the battery seems to be built in with the phone, and I cant figure it out. Is this even possible? Or is the battery just built that way therefore making it impossible to remove? And if so how would I get my phone battery replaced then in the future if I ever needed it when its impossible to even remove it let alone replace???
Well, yeah. You can remove the battery, but the problem is that as far as I know, this model is not compatible with the batteries from other developers. It means that even if you will be somehow able to remove the battery, you have to replace it with the same battery. You can try to see if a company like starlabs.com.sg will be able to help you, because I don’t know so much about it. Maybe it’s possible to manipulate the operational system, but I don’t think that Alcatel is the phone that deserves that much of an attention. Anyway, it’s up to you!
