ISO: Newspaper comic reader
dvandam
I have a Xoom and a N1 and one of the things I like doing on my N1 to kill time is read newspaper comics (Garfield, Calvin & Hobbes, etc.) I have an app on my N1 called Dailystrip that has a wide array of comics. I wanted to get this app for my Xoom but apparently that app doesn't exist anymore. It's not showing up on the market and androidlib has it listed as probably removed. Is there any way to get the app from my phone to the Xoom, or are there newer, similar apps on the market? All the ones I've found seem to have just 1 or limited amounts of strips.
I'll try it out, but it looks like this one has access to significantly less comics and also it says it requires a SD card (which the Xoom STILL doesn't have.) Isn't there a way to transfer apps between devices via 3rd party tools?
None that I know of. What exactly do you want to achieve?
I tried "Comic Reader" app from Applications4android and found it really cool.
Though they have less number of comics, but all the famous ones are there.
And the best thing is there are no ads and it is free.
