Help Issue in APN-GSM disabling
On this phone you don't need to create a fake APN, if you want to disable the mobile 2G/3G internet all you have to do is go Menu>Settings>Wireless & networks>Mobile Networks>Data Enabled. Un-check this option whenever you want to disable the internet on your phone.
It could be setup that way by your phone service provider. I'd suggest to contact them to confirm if there is a different solution that you could try.
