Damon Getsman
Hello everybody.
I have another question regarding Room persistence library. I've been working with it successfully for awhile now, but due to the inability of SQLite to work with a LocalDateTime natively, I'm having some issues now.
Not sure if this is directly relevant, due to the way that I'm handling things, but in my app, I'm saving a timestamp for the following object using the following type converters:
(type converters follow):
In my app, I'm allowing the user to select a date via a Calendar (setting the hour, minute, second, and lower values all to 0) and then I'm trying to utilize a query to select all records prior to the date selected. I then utilize the Calendar.getTimeInMillis() method to attempt to convert this to a value that will be comparable to the epoch second value that is saved in the database with the following code:
Referenced code in Permanence is as follows:
Referenced code via sDb.getUsageDao() is as follows:
The behavior that I am seeing is that when my timestamp > :ts comparison is utilizing greater than (as here), I am getting a count of 0 entries via the query. When this is reversed I'm getting a count for all of the entries. So I'm thinking that either the long values that I'm trying to compare are not equivalent (epoch milliseconds is what I was shooting for w/Calendar.getTimeInMillis() and LocalDateTime.toEpochSecond()), or, well, something else that I don't have a clue about due to the fact that I'm not at any level of serious proficiency with Room or SQLite queries in general at this point.
For brevity's sake, I have omitted portions of the classes referenced above, due to the fact that the boilerplate code is working fine with other methods in the same classes. I apologize if this is a faux pas, and will be more than happy to post more complete examples of the applicable code snippets. Along the same lines, I'm not really sure what else as far as code examples may be applicable to this problem; I think I've hit everything, but if I'm missing something else please let me know and I would be more than happy to post whatever hasn't been properly included. My apologies in advance if anything of the sort has been missed.
I'd like to thank in advance anybody who reads this and especially those who are willing to help me troubleshoot a little bit farther in this process. I'm really not sure where to go with it at this point and I'm very grateful for anything that you may have to offer.
Code:
@Entity
public class Usage {
@PrimaryKey(autoGenerate = true)
private int id;
@ColumnInfo(name="sub_id")
private int sub_id;
@ColumnInfo(name="dosage")
private float dosage;
@ColumnInfo(name="timestamp")
private LocalDateTime timestamp;
@ColumnInfo(name="notes")
private String notes;
Code:
@TypeConverter
public static LocalDateTime toLocalDateTime(long value) {
return LocalDateTime.ofEpochSecond(value, 0, ZoneOffset.UTC);
@TypeConverter
public static long fromLocalDateTime(LocalDateTime ldt) {
return ldt.toEpochSecond(ZoneOffset.UTC);
Code:
public void purgeDatabase(View v) {
if (validateData()) {
//now let's get down to the nitty gritty and delete the entries
GlobalMisc.showSimpleDialog(this, "Wiping entries",
"Purging the database's records on the selected substance prior to the date " +
"that you have selected.");
} else {
GlobalMisc.showSimpleDialog(this, "Not purging anything",
"Not purging any administrations at this time.");
int countToFry = Permanence.getUsagePriorToCount(tmpCal.getTimeInMillis());
GlobalMisc.showSimpleDialog(this, "Toast Count",
"This would toast " + countToFry + " records from the database.");
Code:
public class Permanence {
private static AppDatabase sDb;
public static int getUsagePriorToCount(long ts) {
return sDb.getUsageDao().getPriorToDateUsageCount(ts);
Code:
@Query("SELECT COUNT(*) FROM Usage WHERE timestamp > :ts")
int getPriorToDateUsageCount(long ts);
