Apps Issue with Gravity/Centering
Below is the code...
Code:
<?xml version="1.0" encoding="utf-8"?>
<RelativeLayout xmlns:android="[URL]http://schemas.android.com/apk/res/android[/URL]"
    android:orientation="vertical"
    android:layout_width="fill_parent"
    android:layout_height="fill_parent"
    android:background="#FFFFFF">
    <TextView
     android:id="@+id/tvJoke"
     android:layout_height="wrap_content"
     android:layout_marginTop="20dip"
     android:layout_marginLeft="10dip"
     android:textColor="#000000"
    <LinearLayout
     [B]   android:gravity="bottom"
[/B]     android:layout_below="@id/tvJoke">
  <Button
   android:text="prev"
   android:layout_width="100px"
   android:id="@+id/btnPrevious">
  </Button>
  <Button
   android:text="share"
   android:id="@+id/btnMessage"
   android:layout_height="wrap_content">
  </Button>
  <Button
   android:text="next"
   android:id="@+id/btnNext">
  </Button>
</LinearLayout>
</RelativeLayout>
When I set the gravity in the Linear Layout to Bottom, the three buttons go to the bottom, but they are not horizontally centered. If I set the gravity to center_horizontal, the buttons are no longer aligned against the bottom of the screen - and they shouldn't be in this case...
My question is what is the solution to horizontally center the buttons as well as aligning them toward the bottom?
It would be nice if there was a gravity = "horizontal_center, bottom" -- two options
Any help is much appreciated...
