saptech
Android Expert
I'm having issues with a USB 3.0 ext. hard drive. I can see it when I plug it into the computer, but it's not mounting. I'm using Linux but having same issue with Windows. Any ideas why its not mounting?
Using both OS, it is being picked up but can not access the drive.
Some messages below:
Bus 005 Device 014: ID 0480:a006 Toshiba America Info. Systems, Inc.
# mount -t ntfs /dev/sdc1 /mnt/install
$MFTMirr does not match $MFT (record 0).
Failed to mount '/dev/sdc1': Input/output error
NTFS is either inconsistent, or there is a hardware fault, or it's a
SoftRAID/FakeRAID hardware.
I
I
