Lambertoid
Member
So, my first week back to Android I went 1 year with apple lol.
But as soon as I got my V30 Android auto worked however once I get home and start downloading apps then boom it doesn't work after that. I mean just frustrating and I have learned there are a lot of you with this issues.
Now what fixed mine so far! Is finding out what apps that are side loaded or apps that change the functionality of the device. As many know Android auto can determined if the app is certified or not.
Also the app is changing the skin and the way the device unlocks and locks. I deleted my launcher and deleted my side loaded music apps and re downloaded my AA. Now I'm up and running I will update if anything goes wrong.
Also the app may not be side loaded however if your music app is an app that downloades music like from YouTube that may be the issue. Give it a shot and let me know
Hope this helps
Hope this helps
